Ga door naar hoofdinhoud
Adding a SSD or second HDD to a Asus N73J laptop.
Wat je nodig hebt
  1. Adding a SSD or second HDD to a Asus N73J laptop., Getting access to the screws that hold the back cover in place: stap 1, afbeelding 1 van 3 Adding a SSD or second HDD to a Asus N73J laptop., Getting access to the screws that hold the back cover in place: stap 1, afbeelding 2 van 3 Adding a SSD or second HDD to a Asus N73J laptop., Getting access to the screws that hold the back cover in place: stap 1, afbeelding 3 van 3
    • Use a small flathead screwdriver or the flat end of a spudger to gently push down the five pins just above the top row of keys that secure the keyboard to the laptop.
  2. Adding a SSD or second HDD to a Asus N73J laptop.: stap 2, afbeelding 1 van 2 Adding a SSD or second HDD to a Asus N73J laptop.: stap 2, afbeelding 2 van 2
    • Slowly tilt the keyboard towards the front but not too far as the flat cable is still connected.
  3. Adding a SSD or second HDD to a Asus N73J laptop.: stap 3, afbeelding 1 van 2 Adding a SSD or second HDD to a Asus N73J laptop.: stap 3, afbeelding 2 van 2
    • With a spudger carefully unlock the socket by pushing the white part to the left. Pull the ribbon cable straight out of its socket.
    • (For a clear view the photo shows where to push after the cable was already removed; push both from upper side as bottom side of the socket.)
  4. Adding a SSD or second HDD to a Asus N73J laptop., Removing the screws that hold the back cover in place: stap 4, afbeelding 1 van 1
    • Remove these seven screws with a JIS #1 (or PH 1) to unlock the back cover.
    • Here you can see the slot for an extra RAM module.
    • When finished close the laptop and turn it over.
  5. Adding a SSD or second HDD to a Asus N73J laptop., Removing the back cover: stap 5, afbeelding 1 van 3 Adding a SSD or second HDD to a Asus N73J laptop., Removing the back cover: stap 5, afbeelding 2 van 3 Adding a SSD or second HDD to a Asus N73J laptop., Removing the back cover: stap 5, afbeelding 3 van 3
    • Open the back cover to get access to:
    • the HDD-bays
    • the RAM modules
    • the WiFI module
  6. Adding a SSD or second HDD to a Asus N73J laptop., Preparing the SSD or HDD: stap 6, afbeelding 1 van 2 Adding a SSD or second HDD to a Asus N73J laptop., Preparing the SSD or HDD: stap 6, afbeelding 2 van 2
    • If you haven't done so already now is the time to mount your SSD or HDD in the caddy.
  7. Adding a SSD or second HDD to a Asus N73J laptop., Placing the SSD or HDD: stap 7, afbeelding 1 van 2 Adding a SSD or second HDD to a Asus N73J laptop., Placing the SSD or HDD: stap 7, afbeelding 2 van 2
    • Gently slide your new SSD/HDD in the empty HDD bay. And do not forget to secure it to the body of the laptop with a few screws.
Conclusie
6 andere personen hebben deze handleiding voltooid.
EricV
758 Reputatie
2 handleidingen geschreven
3 opmerkingen
Why take off the keyboard to install an SSD? Would not removing the back drive bay cover be all that is necessary to gain access to the drive bays?
William - Antwoord
You have to remove the keyboard in order to get access to the screws that hold the back cover in place.
EricV -
Great help with the pics. Thank you so much
chandra sekhar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 58
Altijd: 15,203
