Ga door naar hoofdinhoud
Acrylic Nail Tip Replacement
Wat je nodig hebt
  1. Acrylic Nail Tip Replacement, Acrylic Nail Tip: stap 1, afbeelding 1 van 1
    • File the nail in a back-and-forth motion with the nail file on the accessible part of the natural nail until it is no longer smooth.
    • Try not to file the acrylic nail that is is still attached to your natural nail, as it will not fit the part that broke.
  2. Acrylic Nail Tip Replacement: stap 2, afbeelding 1 van 1
    • Carefully place a drop of nail glue on the natural nail and let the glue sit for about 5 seconds.
    • Do not use more than 1-2 drops of nail glue.
  3. Acrylic Nail Tip Replacement: stap 3, afbeelding 1 van 2 Acrylic Nail Tip Replacement: stap 3, afbeelding 2 van 2
    • Place a nail tip in its original position and hold it in place for about 20 seconds, or until it is fully dry.
  4. Acrylic Nail Tip Replacement: stap 4, afbeelding 1 van 2 Acrylic Nail Tip Replacement: stap 4, afbeelding 2 van 2
    • Pour 30 milliliters of monomer in a small glass bowl.
    • Liquid nail monomer has a strong odor and is highly flammable.
    • Do not reuse the glass bowl for any food products because of possible chemical residue.
  5. Acrylic Nail Tip Replacement: stap 5, afbeelding 1 van 3 Acrylic Nail Tip Replacement: stap 5, afbeelding 2 van 3 Acrylic Nail Tip Replacement: stap 5, afbeelding 3 van 3
    • Dip the brush in the monomer and lightly tap it on the paper towel to remove the excess.
  6. Acrylic Nail Tip Replacement: stap 6, afbeelding 1 van 2 Acrylic Nail Tip Replacement: stap 6, afbeelding 2 van 2
    • Place the tip of the brush in clear acrylic powder at about an 80-degree angle; collect it on one side of the brush.
  7. Acrylic Nail Tip Replacement: stap 7, afbeelding 1 van 3 Acrylic Nail Tip Replacement: stap 7, afbeelding 2 van 3 Acrylic Nail Tip Replacement: stap 7, afbeelding 3 van 3
    • Apply the acrylic powder to the nail, and in a dabbing, downward motion, smooth the acrylic over the nail from top to bottom.
  8. Acrylic Nail Tip Replacement: stap 8, afbeelding 1 van 1
    • Place the nail under the UV/LED lamp until hard and firm.
  9. Acrylic Nail Tip Replacement: stap 9, afbeelding 1 van 3 Acrylic Nail Tip Replacement: stap 9, afbeelding 2 van 3 Acrylic Nail Tip Replacement: stap 9, afbeelding 3 van 3
    • Use a nail drill to file the nail to achieve an even acrylic coat by drilling in a side-to-side motion, working your way from top to bottom.
    • Use a speed of 7-9 on the nail drill.
    • If you do not have a nail drill, you can also use a nail file.
  10. Acrylic Nail Tip Replacement: stap 10, afbeelding 1 van 3 Acrylic Nail Tip Replacement: stap 10, afbeelding 2 van 3 Acrylic Nail Tip Replacement: stap 10, afbeelding 3 van 3
    • Buff the nail until it is smooth, and use a paper towel to wipe off excess powder.
  11. Acrylic Nail Tip Replacement: stap 11, afbeelding 1 van 3 Acrylic Nail Tip Replacement: stap 11, afbeelding 2 van 3 Acrylic Nail Tip Replacement: stap 11, afbeelding 3 van 3
    • Optional: coat the nail with clear polish.
Eindstreep
Alysia Williams
194 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 253
