Ga door naar hoofdinhoud
Acer TravelMate TMB115-M-C99B Motherboard Replacement
Wat je nodig hebt
  1. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 2, afbeelding 1 van 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 2, afbeelding 2 van 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 4, afbeelding 1 van 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: stap 5, afbeelding 1 van 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: stap 5, afbeelding 2 van 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: stap 5, afbeelding 3 van 3
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 9, afbeelding 1 van 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 10, afbeelding 1 van 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Melissa Martinez
279 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G5, White Winter 2019 Lid van Cal Poly, Team S1-G5, White Winter 2019
CPSU-WHITE-W19S1G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 559
