Ga door naar hoofdinhoud
Acer Swift X N20C12 Trackpad Replacement
Wat je nodig hebt
  1. Acer Swift X N20C12 Trackpad Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Trackpad Replacement: stap 2, afbeelding 1 van 1
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Trackpad Replacement, Battery: stap 3, afbeelding 1 van 1
    • Grasp the battery connector and pull it directly out of its socket.
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws that secure the battery.
  4. Acer Swift X N20C12 Trackpad Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and out of the chassis.
  5. Acer Swift X N20C12 Trackpad Replacement, Trackpad: stap 5, afbeelding 1 van 1
    • Use a Phillips # 1 screwdriver to remove the 2.9 mm screws that secure the trackpad.
    • Disconnect the trackpad connector.
  6. Acer Swift X N20C12 Trackpad Replacement: stap 6, afbeelding 1 van 1
    • Lift the trackpad up and out of the chassis.
Conclusie
Abrar
471 Reputatie
5 handleidingen geschreven
Gateway, Team 1-2, Pee Fall 2023 Lid van Gateway, Team 1-2, Pee Fall 2023
GCC-PEE-F23S1G2
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 106
