Ga door naar hoofdinhoud
Acer Spin 7 SP714-51 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 2 van 3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 3 van 3
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface, such as a table.
    • Using a standard PH0 Phillips-head screwdriver, work your way around the edge removing the 6mm screws along the way.
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
    • Once the back cover is removed, make sure you disconnect the battery cable.
  2. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Disconnect the white and black antennae from the Wi-Fi card.
    • The Wi-Fi card is located on the left side of the laptop when it is flipped to see the bottom of the laptop.
    • The antennae should snap off upwards easily with a pry tool so the antennae and Wi-Fi card no longer connect.
  3. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Acer Spin 7 SP714-51 Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the 6 mm retaining screw from the Wi-Fi card, and carefully pull the card free to remove it from the laptop.
Conclusie
Zach Desrosiers
565 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 Lid van UMass Dartmouth, Team 7-3, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 245
