Wat je nodig hebt
Remove the two Phillips #0 screws holding the battery inside the laptop case.
Using your nails or tweezers, unplug the charger port cable from the motherboard.
Lift the three black tabs to release the cable connectors.
After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
Remove the screws from the "L" and "R" plastic pieces using a Phillips #0 screwdriver.
Bijna klaar!
Conclusie
