Ga door naar hoofdinhoud
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
Wat je nodig hebt
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: stap 1, afbeelding 1 van 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: stap 1, afbeelding 2 van 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: stap 2, afbeelding 1 van 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: stap 2, afbeelding 2 van 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: stap 4, afbeelding 1 van 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: stap 5, afbeelding 1 van 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: stap 6, afbeelding 1 van 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: stap 7, afbeelding 1 van 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: stap 7, afbeelding 2 van 2
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: stap 8, afbeelding 1 van 1
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
Conclusie
Jeffrey Kong
809 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-3, Forte Fall 2014 Lid van Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 2,771
