Ga door naar hoofdinhoud
Acer Predator Helios 300 Battery Replacement
Wat je nodig hebt
  1. Acer Predator Helios 300 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before you start make sure the laptop is grounded.
    • Make sure the laptop is powered off.
    • If the laptop is not turned off, there is a risk of electric shock when replacing the battery.
    • Close the cover of the laptop, then turn the laptop upside down so the back is facing up.
  2. Acer Predator Helios 300 Battery Replacement: stap 2, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement: stap 2, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove all the screws from the back panel with a Phillips #0 screwdriver.
    • Remove the hard drive screw using a Phillips #0 screwdriver.
    • Use the panel tool to pop the storage hard disk open.
  3. Acer Predator Helios 300 Battery Replacement: stap 3, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement: stap 3, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the four screws mounted near the storage hard disk using a Phillips #0 screwdriver.
    • Disconnect the cable connected to the storage hard disk.
  4. Acer Predator Helios 300 Battery Replacement: stap 4, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement: stap 4, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement: stap 4, afbeelding 3 van 3
    • Use the panel tool to remove the back cover.
    • Slowly open the clips attached to the back cover, and store the cover safely.
  5. Acer Predator Helios 300 Battery Replacement: stap 5, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement: stap 5, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the tape holding the battery wires in.
    • Remove the two screws mounted next to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard slowly.
    • Remove the old battery.
  6. Acer Predator Helios 300 Battery Replacement: stap 6, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement: stap 6, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement: stap 6, afbeelding 3 van 3
    • The battery is a Household Hazardous Waste, so be sure to follow your city's laws and dispose of them properly.
    • Connect the new battery connector to the motherboard and screw it back with the screwdriver.
  7. Acer Predator Helios 300 Battery Replacement: stap 7, afbeelding 1 van 2 Acer Predator Helios 300 Battery Replacement: stap 7, afbeelding 2 van 2
    • Align the back cover with the laptop properly and click it with all the clips.
  8. Acer Predator Helios 300 Battery Replacement: stap 8, afbeelding 1 van 3 Acer Predator Helios 300 Battery Replacement: stap 8, afbeelding 2 van 3 Acer Predator Helios 300 Battery Replacement: stap 8, afbeelding 3 van 3
    • Insert the storage disk back in.
    • Connect it with the cable first and then fit it inside the missing space.
    • Fasten the remaining screws using a screwdriver.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Sidharth Rajeev
184 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 203
Altijd: 594
