Inleiding
Use this guide to change the battery on your Acer Predator Helios 300 (2020).
Model Number: PH3-15-53
The laptop battery is essential to provide portable usage since it keeps the laptop powered on.
You might want to replace your laptop battery if it is slow to charge or overheating. If the laptop is not charging, you might want to check if the power adapter for the battery is plugged in correctly before you replace the battery.
If you decide to follow this guide, what you will need is a Philp’s screwdriver and the replacement battery in order to get started.
Wat je nodig hebt
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
