Ga door naar hoofdinhoud
Acer Predator 17 G9-791 Motherboard Replacement
Wat je nodig hebt
  1. Acer Predator 17 G9-791 Motherboard Replacement, Service Panel: stap 1, afbeelding 1 van 1
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Motherboard Replacement: stap 2, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Motherboard Replacement, Bottom Case: stap 4, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement, Bottom Case: stap 4, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement, Bottom Case: stap 4, afbeelding 3 van 3
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Motherboard Replacement, Battery: stap 8, afbeelding 1 van 1
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Motherboard Replacement: stap 9, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Motherboard Replacement, Fan Assembly: stap 11, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement, Fan Assembly: stap 11, afbeelding 2 van 2
    • Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
  12. Acer Predator 17 G9-791 Motherboard Replacement: stap 12, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
  13. Acer Predator 17 G9-791 Motherboard Replacement: stap 13, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 13, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Detach the left fan's cord from the motherboard.
  14. Acer Predator 17 G9-791 Motherboard Replacement: stap 14, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 14, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Detach the right fan's cord from the motherboard.
  15. Acer Predator 17 G9-791 Motherboard Replacement: stap 15, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 15, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Lift the fan assembly up and out.
  16. Acer Predator 17 G9-791 Motherboard Replacement, Motherboard: stap 16, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #0 screws from the small PCB.
  17. Acer Predator 17 G9-791 Motherboard Replacement: stap 17, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 17, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Pull the small PCB to the right and then up to remove it from the device.
  18. Acer Predator 17 G9-791 Motherboard Replacement: stap 18, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Pull up on the “woofer” wire to remove it from its connector.
  19. Acer Predator 17 G9-791 Motherboard Replacement: stap 19, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Remove the two connectors.
  20. Acer Predator 17 G9-791 Motherboard Replacement: stap 20, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Separate the same two wires from the subwoofer.
  21. Acer Predator 17 G9-791 Motherboard Replacement: stap 21, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 21, afbeelding 2 van 2
    • Pull the subwoofer up and out of the device.
  22. Acer Predator 17 G9-791 Motherboard Replacement: stap 22, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 22, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 22, afbeelding 3 van 3
    • Remove the six connectors.
    • Some require you to flip the white part of the connector up first to remove them.
  23. Acer Predator 17 G9-791 Motherboard Replacement: stap 23, afbeelding 1 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 23, afbeelding 2 van 3 Acer Predator 17 G9-791 Motherboard Replacement: stap 23, afbeelding 3 van 3
    • Remove one 4.5 mm Phillips #0 screw from the WLAN card and pull the card out.
  24. Acer Predator 17 G9-791 Motherboard Replacement: stap 24, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Remove six 5 mm Phillips #0 screws from the motherboard.
  25. Acer Predator 17 G9-791 Motherboard Replacement: stap 25, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 25, afbeelding 2 van 2
    • Turn the device around.
    • Use the black tab to disconnect the one connector on the bottom of the motherboard.
    • When reinstalling you should plug this connector back in as you set the motherboard down.
  26. Acer Predator 17 G9-791 Motherboard Replacement: stap 26, afbeelding 1 van 1
    • Remove the two black 7 mm Phillips #0 screws from the left display bracket.
  27. Acer Predator 17 G9-791 Motherboard Replacement: stap 27, afbeelding 1 van 1
    • Remove the two silver 5 mm Phillips #0 screws from the left display bracket.
  28. Acer Predator 17 G9-791 Motherboard Replacement: stap 28, afbeelding 1 van 2 Acer Predator 17 G9-791 Motherboard Replacement: stap 28, afbeelding 2 van 2
    • Pull the motherboard up and out of the device. You may need to open the lid slightly for the removal process.
    • When reinstalling the motherboard, ensure that wires do not get stuck under the motherboard as you set it back down.
Conclusie
Jimmy Coffey
220 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 Lid van UMass Dartmouth, Team 5-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G1
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 713
