Ga door naar hoofdinhoud
Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair
Wat je nodig hebt
  1. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: stap 1, afbeelding 1 van 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: stap 1, afbeelding 2 van 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: stap 2, afbeelding 1 van 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: stap 3, afbeelding 1 van 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: stap 3, afbeelding 2 van 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: stap 3, afbeelding 3 van 3
    • Flip the latch and carefully pull the ribbon free.
  4. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: stap 4, afbeelding 1 van 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: stap 4, afbeelding 2 van 2
    • Remove the two screws holding the dock in place using a Phillips #0 screwdriver.
    • Pull the dock out and slide it out of the device.
Conclusie
Trey Wintzinger
605 Reputatie
5 handleidingen geschreven
Één opmerking
dove acquistare questo connettore :Acer ONE 10 (S1003 D16H1) Docking Port Connector Cable, grazie . francescomar25@gmail.com
Francesco - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 1,248
