Inleiding
This guide will show you how to successfully replace a damaged or dead battery in your device.
Wat je nodig hebt
Power off the device and make sure it is disconnected from any external devices.
Use a plastic opening tool to create a gap between the front and back casing of the device.
Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
Remove the two pieces of transparent yellow tape inside the device.
Using the Phillips #0 screwdriver, remove the two screws on either side of the connector.
Grab the the connector with tweezers and pull it slightly away from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
