Ga door naar hoofdinhoud
Acer One 10 S1002 145-A Screen Replacement
Wat je nodig hebt
  1. Acer One 10 S1002 145-A Screen Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Screen Replacement: stap 2, afbeelding 1 van 2 Acer One 10 S1002 145-A Screen Replacement: stap 2, afbeelding 2 van 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Screen Replacement: stap 3, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 3, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 3, afbeelding 3 van 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Screen Replacement: stap 4, afbeelding 1 van 2 Acer One 10 S1002 145-A Screen Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Screen Replacement: stap 5, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 5, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 5, afbeelding 3 van 3
  6. Acer One 10 S1002 145-A Screen Replacement: stap 6, afbeelding 1 van 2 Acer One 10 S1002 145-A Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Screen Replacement: stap 7, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 7, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Screen Replacement: stap 8, afbeelding 1 van 1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Screen Replacement, Battery: stap 9, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement, Battery: stap 9, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement, Battery: stap 9, afbeelding 3 van 3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
  10. Acer One 10 S1002 145-A Screen Replacement, Camera: stap 10, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement, Camera: stap 10, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement, Camera: stap 10, afbeelding 3 van 3
    • Separate the adhesive cable from the underlying copper ribbon cable.
    • Gently pry off the camera from from tablet backing.
    • Remove the camera and set it aside.
  11. Acer One 10 S1002 145-A Screen Replacement, Screen: stap 11, afbeelding 1 van 2 Acer One 10 S1002 145-A Screen Replacement, Screen: stap 11, afbeelding 2 van 2
    • Open the latch on the copper connector and remove it from the tablet.
  12. Acer One 10 S1002 145-A Screen Replacement: stap 12, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 12, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 12, afbeelding 3 van 3
    • Remove the three 3.5mm screws from the outside perimeter of the tablet.
  13. Acer One 10 S1002 145-A Screen Replacement: stap 13, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 13, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 13, afbeelding 3 van 3
    • Remove the three small latches that are underneath the screws.
  14. Acer One 10 S1002 145-A Screen Replacement: stap 14, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 14, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 14, afbeelding 3 van 3
    • Peel the silver tape on the side of the tablet using the nylon spudger. Do not completely remove the tape.
    • Peel the gold tape gently. Do not completely remove the tape.
  15. Acer One 10 S1002 145-A Screen Replacement: stap 15, afbeelding 1 van 2 Acer One 10 S1002 145-A Screen Replacement: stap 15, afbeelding 2 van 2
    • Locate the small green connector with the black cable attached.
    • Disconnect the black cable from the small green connector using the precision tweezers.
    • Use a heating pack (iOpener), a hair dryer, or heat gun, and place it over the highlighted glue areas.
    • This will heat up the glue beneath the tape in order to separate the LCD from the screen.
  16. Acer One 10 S1002 145-A Screen Replacement: stap 17, afbeelding 1 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 17, afbeelding 2 van 3 Acer One 10 S1002 145-A Screen Replacement: stap 17, afbeelding 3 van 3
    • Using the nylon spudger, gently pry the LCD from the screen.
    • Once separated, gently lift away the LCD from the screen.
    • Place tablet screen to the side.
Conclusie
Shannon Griffin
1.339 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Fall 2016 Lid van USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 9,104
