Ga door naar hoofdinhoud
Acer One 10 S1002 145-A Key Replacement
Wat je nodig hebt
  1. Acer One 10 S1002 145-A Key Replacement, Key: stap 1, afbeelding 1 van 1
    • Make sure device is powered off and disconnected from any power supply.
    • Disconnect the tablet screen from the magnetic hinge where the keyboard is attached.
    • Pry off the damaged key by using the nylon spudger to gently push the key upwards.
  2. Acer One 10 S1002 145-A Key Replacement: stap 2, afbeelding 1 van 1
    • If the white plastic horizontal spring becomes misaligned, re-align and pop the two hinges back into place with the tweezers or your fingers.
Conclusie
Shannon Griffin
1.339 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Fall 2016 Lid van USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 7,782
