Ga door naar hoofdinhoud
Acer Nitro 5 AN517-51-56YW Battery Replacement
Wat je nodig hebt
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: stap 3, afbeelding 1 van 2 Acer Nitro 5 AN517-51-56YW Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
Conclusie
Jacob Elkins
221 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 67
Altijd: 1,624
