Ga door naar hoofdinhoud
Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 2, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying it up with a plastic opening tool.
  3. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Remove the screw on the Hard Drive tray with a Phillips #0 screwdriver.
    • Lift up the tray covering using a plastic opening tool.
  4. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the fourteen 9mm screws holding the back cover in place.
    • Remove the hard drive (if applicable) from the slot prior to removing the back cover.
    • This device didn't have a hard drive so your device may look different.
  5. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 5, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 5, afbeelding 3 van 3
    • Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 1
    • Lift the back cover off once all the clips have been disengaged.
  7. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 7, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 7, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 7, afbeelding 3 van 3
    • Using your fingers, disconnect the white and black cables connected to the left side of the Wi-fi card.
  8. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 8, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 8, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 8, afbeelding 3 van 3
    • Remove the screw holding down the Wi-Fi card with a Phillips #0 screwdriver.
  9. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 9, afbeelding 1 van 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: stap 9, afbeelding 2 van 2
    • Slide the Wi-Fi card out from its port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
My hard drive got disconnected and I can't locate where is the place to connect it
manueltopete59 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 87
Altijd: 6,155
