Ga door naar hoofdinhoud
Acer Nitro 5 AN515-53-55G9 Touchpad Replacement
Wat je nodig hebt
  1. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 2, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 2, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 2, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 3, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 3, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 3, afbeelding 3 van 3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 5, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 5, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 5, afbeelding 3 van 3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 6, afbeelding 1 van 2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 6, afbeelding 2 van 2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 7, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 7, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 7, afbeelding 3 van 3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: stap 9, afbeelding 1 van 2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: stap 9, afbeelding 2 van 2
    • Locate the Touchpad in the lower middle of the device.
    • Locate and remove the 4mm screws that hold the Touchpad in place.
  10. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 10, afbeelding 1 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 10, afbeelding 2 van 3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 10, afbeelding 3 van 3
    • Locate the Touchpad's connector.
    • Use a plastic spudger to pry up the small plastic clip on the connector port.
    • Gently pull the cable out of the port.
  11. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: stap 11, afbeelding 1 van 1
    • Lift up the Touchpad and remove it from the device.
Conclusie
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
And where can I find the track pad replacement? Thanks.
xRiiad _YouTube - Antwoord
You can purchase replacement trackpads online, on eBay or Amazon or many other places by simply Google searching “Acer Nitro 5 Touchpad Part”
Rheo Bruer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 49
Altijd: 5,716
