Ga door naar hoofdinhoud
Acer Nitro 5 AN515-53-52FA Battery Replacement
Wat je nodig hebt
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 2, afbeelding 1 van 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 3, afbeelding 1 van 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 5, afbeelding 1 van 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 6, afbeelding 1 van 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery up and out of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alfredo Prieto
827 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Pee Fall 2022 Lid van Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Leden
2 opmerkingen
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Antwoord
Can I use a Jimmy instead of the opening picks?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 65
Altijd: 897
