Ga door naar hoofdinhoud
Acer Iconia W3-810 Speaker Replacement
Wat je nodig hebt
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: stap 12, afbeelding 1 van 1
    • Remove the speakers from the device.
Conclusie
Griffin Hocker
394 Reputatie
3 handleidingen geschreven
USF Tampa, Team 18-4, Blackwell Fall 2016 Lid van USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 432
