Ga door naar hoofdinhoud
Acer Iconia W3-810 Rear-Facing Camera Replacement
Wat je nodig hebt
  1. Acer Iconia W3-810 Rear-Facing Camera Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Rear-Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Rear-Facing Camera Replacement, Rear-Facing Camera: stap 3, afbeelding 1 van 1
    • Lift the retaining flap fastening the ribbon cord to the motherboard using a plastic opening tool.
  4. Acer Iconia W3-810 Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the ribbon cord from its slot using a plastic opening tool.
  5. Acer Iconia W3-810 Rear-Facing Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the rear-facing camera from its slot and pose for a camera shot.
Conclusie
Adam Fierce
418 Reputatie
3 handleidingen geschreven
USF Tampa, Team 18-4, Blackwell Fall 2016 Lid van USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 463
