Ga door naar hoofdinhoud
Acer Iconia Tab B1 Factory Hard Reset/Password Removal
Video overzicht
  1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 1, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 1, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 1, afbeelding 3 van 3
    • From the reset hole we can make reset without erasing data.
  2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 2, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 2, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 2, afbeelding 3 van 3
    • Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
  3. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 3, afbeelding 1 van 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 3, afbeelding 2 van 2
    • Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
    • Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
    Hi when i make it, fastboot mode was in the screen
    Sihem Smiti - Antwoord
  4. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 4, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 4, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 4, afbeelding 3 van 3
    • Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
  5. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 5, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 5, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 5, afbeelding 3 van 3
    • After restart you will have empty (free of data) device and access to it.
    buen dia la tablet se queda en la pantalla de welcome que hago
    Frank Rondon - Antwoord
Conclusie
11 andere personen hebben deze handleiding voltooid.
ZFix
191.368 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.468 handleidingen geschreven
2 opmerkingen
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
martinez1816 - Antwoord
I have the same problem when it came to SD image update mode I get the acer logo and it restarts it does not pass to the android logo it geast restart
Claudiu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 70,708
