Ga door naar hoofdinhoud
Acer Iconia Tab B1 Factory Hard Reset/Password Removal
Video overzicht
  1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 1, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 1, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 1, afbeelding 3 van 3
    • From the reset hole we can make reset without erasing data.
  2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 2, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 2, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 2, afbeelding 3 van 3
    • Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
  3. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 3, afbeelding 1 van 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 3, afbeelding 2 van 2
    • Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
    • Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
  4. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 4, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 4, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 4, afbeelding 3 van 3
    • Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
  5. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 5, afbeelding 1 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 5, afbeelding 2 van 3 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: stap 5, afbeelding 3 van 3
    • After restart you will have empty (free of data) device and access to it.
Conclusie
11 andere personen hebben deze handleiding voltooid.
ZFix
191.368 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.468 handleidingen geschreven
2 opmerkingen
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
martinez1816 - Antwoord
I have the same problem when it came to SD image update mode I get the acer logo and it restarts it does not pass to the android logo it geast restart
Claudiu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 70,708
