Ga door naar hoofdinhoud
Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement
Wat je nodig hebt
  1. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 2, afbeelding 1 van 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, USB-A/Micro-USB Port: stap 3, afbeelding 1 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, USB-A/Micro-USB Port: stap 3, afbeelding 2 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, USB-A/Micro-USB Port: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    $3.99
    Koop
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 4, afbeelding 1 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 4, afbeelding 2 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to flip up the locking mechanism for the flat, white ribbon cable connecting to the USB ports' board.
    • Remove the flat, white ribbon cable.
  5. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 5, afbeelding 1 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 5, afbeelding 2 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the two 4.0 mm Philips screws attaching the metal plate, USB board, and device.
  6. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 6, afbeelding 1 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 6, afbeelding 2 van 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: stap 6, afbeelding 3 van 3
    • Use the Halberd Spudger to carefully pop up and take out the ports.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 272
