Ga door naar hoofdinhoud
Acer Iconia Tab A501 Speaker Replacement
Wat je nodig hebt
  1. Acer Iconia Tab A501 Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Iconia Tab A501 Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Iconia Tab A501 Speaker Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Speaker Replacement: stap 2, afbeelding 1 van 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Speaker Replacement, Speaker: stap 3, afbeelding 1 van 3 Acer Iconia Tab A501 Speaker Replacement, Speaker: stap 3, afbeelding 2 van 3 Acer Iconia Tab A501 Speaker Replacement, Speaker: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    $3.99
    Koop
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Speaker Replacement: stap 4, afbeelding 1 van 3 Acer Iconia Tab A501 Speaker Replacement: stap 4, afbeelding 2 van 3 Acer Iconia Tab A501 Speaker Replacement: stap 4, afbeelding 3 van 3
    • In this step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly toward the side with the Micro-HDMI port relative to the docking port.
  5. Acer Iconia Tab A501 Speaker Replacement: stap 5, afbeelding 1 van 3 Acer Iconia Tab A501 Speaker Replacement: stap 5, afbeelding 2 van 3 Acer Iconia Tab A501 Speaker Replacement: stap 5, afbeelding 3 van 3
    • Unscrew the 3.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
    • Unscrew the 4.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
  6. Acer Iconia Tab A501 Speaker Replacement: stap 6, afbeelding 1 van 3 Acer Iconia Tab A501 Speaker Replacement: stap 6, afbeelding 2 van 3 Acer Iconia Tab A501 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Remove the speakers.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 126
