Ga door naar hoofdinhoud
Acer Iconia Tab A501 Docking Port Replacement
Wat je nodig hebt
  1. Acer Iconia Tab A501 Docking Port Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Iconia Tab A501 Docking Port Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Iconia Tab A501 Docking Port Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Docking Port Replacement: stap 2, afbeelding 1 van 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Docking Port Replacement, Docking Port: stap 3, afbeelding 1 van 3 Acer Iconia Tab A501 Docking Port Replacement, Docking Port: stap 3, afbeelding 2 van 3 Acer Iconia Tab A501 Docking Port Replacement, Docking Port: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    $3.99
    Koop
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Docking Port Replacement: stap 4, afbeelding 1 van 3 Acer Iconia Tab A501 Docking Port Replacement: stap 4, afbeelding 2 van 3 Acer Iconia Tab A501 Docking Port Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to flip up the locking mechanism for the ribbon cable on the docking port board that is flat, white, and folded.
    • Detach the folded, white ribbon cable on the docking port board.
  5. Acer Iconia Tab A501 Docking Port Replacement: stap 5, afbeelding 1 van 2 Acer Iconia Tab A501 Docking Port Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
  6. Acer Iconia Tab A501 Docking Port Replacement: stap 6, afbeelding 1 van 2 Acer Iconia Tab A501 Docking Port Replacement: stap 6, afbeelding 2 van 2
    • Remove the docking port.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 148
