Ga door naar hoofdinhoud
Acer Iconia One 8 Battery Replacement
Wat je nodig hebt
  1. Acer Iconia One 8 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Iconia One 8 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: stap 3, afbeelding 1 van 1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: stap 4, afbeelding 1 van 1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
Conclusie
Josh Cooper
319 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 2,848
