Ga door naar hoofdinhoud
Acer Iconia One 7 Speaker Replacement
Wat je nodig hebt
  1. Acer Iconia One 7 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult; use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Turn the tablet over to locate the speaker.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
    • The speaker is on the bottom of the inside.
  4. Acer Iconia One 7 Speaker Replacement: stap 4, afbeelding 1 van 2 Acer Iconia One 7 Speaker Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Peel back tape.
    • Using tweezers, detach connection from motherboard.
  5. Acer Iconia One 7 Speaker Replacement: stap 5, afbeelding 1 van 3 Acer Iconia One 7 Speaker Replacement: stap 5, afbeelding 2 van 3 Acer Iconia One 7 Speaker Replacement: stap 5, afbeelding 3 van 3
    • Unscrew screws with a JIS screwdriver with a #00 screw bit.
    • Dislodge the speaker unit.
    • Take care not to displace any other bits in the device.
Conclusie
Michael
519 Reputatie
4 handleidingen geschreven
USF Tampa, Team 8-5, Eyestone Fall 2015 Lid van USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 423
