Ga door naar hoofdinhoud
Acer Iconia One 7 Rear-Facing Camera Replacement
Wat je nodig hebt
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: stap 1, afbeelding 1 van 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 2 Acer Iconia One 7 Rear-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: stap 5, afbeelding 1 van 2 Acer Iconia One 7 Rear-Facing Camera Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Conclusie
Michael
519 Reputatie
4 handleidingen geschreven
USF Tampa, Team 8-5, Eyestone Fall 2015 Lid van USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Leden
5 handleidingen geschreven
Één opmerking
How to get new camera if the original camera is damaged
Prakash Hasabnis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 443
