Ga door naar hoofdinhoud
Acer Iconia One 7 Motherboard Replacement
Wat je nodig hebt
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Iconia One 7 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: stap 8, afbeelding 1 van 2 Acer Iconia One 7 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Gently pull out motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Michael
519 Reputatie
4 handleidingen geschreven
USF Tampa, Team 8-5, Eyestone Fall 2015 Lid van USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 2,568
