Ga door naar hoofdinhoud
Acer Iconia One 7 Front Facing Camera Replacement
Wat je nodig hebt
  1. Acer Iconia One 7 Front Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 1 van 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Front Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Front Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Turn tablet over.
    • Locate front-facing camera.
  4. Acer Iconia One 7 Front Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Pull black tape with front-facing camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael
519 Reputatie
4 handleidingen geschreven
USF Tampa, Team 8-5, Eyestone Fall 2015 Lid van USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Leden
5 handleidingen geschreven
Één opmerking
Be carefful when pulling the stick tape. It is very strong and can break the flex cable of the camera and other flex cables...
Egas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,149
