Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
Using a plastic opening tool, separate the back cover from the main device.
Open each side continuously to ensure all sides have been separated.
Carefully pull back the black tape covering the battery lead connector.
Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99-
Using a plastic card or opening pick, separate the battery from the rest of the device.
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
Where I can order the new battery part?
