Ga door naar hoofdinhoud
Acer Iconia B1-720 Battery Replacement
Wat je nodig hebt
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 Acer Iconia B1-720 Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 Acer Iconia B1-720 Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: stap 2, afbeelding 1 van 3 Acer Iconia B1-720 Battery Replacement: stap 2, afbeelding 2 van 3 Acer Iconia B1-720 Battery Replacement: stap 2, afbeelding 3 van 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: stap 3, afbeelding 1 van 2 Acer Iconia B1-720 Battery Replacement: stap 3, afbeelding 2 van 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Acer Iconia B1-720 Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: stap 6, afbeelding 1 van 3 Acer Iconia B1-720 Battery Replacement: stap 6, afbeelding 2 van 3 Acer Iconia B1-720 Battery Replacement: stap 6, afbeelding 3 van 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kervis Boston
479 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-1, Lauer Spring 2015 Lid van Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
2 Leden
5 handleidingen geschreven
2 opmerkingen
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - Antwoord
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 2,889
