Ga door naar hoofdinhoud
Acer Iconia B1-711 LCD Display Replacement
Wat je nodig hebt
Video overzicht
  1. Acer Iconia B1-711 LCD Display Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 LCD Display Replacement: stap 2, afbeelding 1 van 2 Acer Iconia B1-711 LCD Display Replacement: stap 2, afbeelding 2 van 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 LCD Display Replacement, Battery: stap 3, afbeelding 1 van 2 Acer Iconia B1-711 LCD Display Replacement, Battery: stap 3, afbeelding 2 van 2
    • With a long plastic tool like a spudger, unstick the battery from the metal LCD shield.
    • Lithium Ion Battery Pack - 3.8V, 2710mAh
  4. Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: stap 4, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: stap 4, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: stap 4, afbeelding 3 van 3
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
  5. Acer Iconia B1-711 LCD Display Replacement, Camera: stap 5, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement, Camera: stap 5, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement, Camera: stap 5, afbeelding 3 van 3
    • Remove the Audio jack flex cable.
    • Remove the metal plate which is placed on the camera connector.
    • Disconnect the camera flex cable.
  6. Acer Iconia B1-711 LCD Display Replacement: stap 6, afbeelding 1 van 1
    • Remove the camera.
  7. Acer Iconia B1-711 LCD Display Replacement, Microphone: stap 7, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement, Microphone: stap 7, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement, Microphone: stap 7, afbeelding 3 van 3
    • Remove the tape from the microphone.
    • Disconnect the Microphone wires and remove the Microphone.
  8. Acer Iconia B1-711 LCD Display Replacement, Logic Board: stap 8, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement, Logic Board: stap 8, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement, Logic Board: stap 8, afbeelding 3 van 3
    • Remove the green rubber and disconnect the touch screen flex cable.
    • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
    • Carefully unstuck the metal folio from the LCD display flex cable.
    • Remove the 3x Phillips screws.
  9. Acer Iconia B1-711 LCD Display Replacement: stap 9, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 9, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 9, afbeelding 3 van 3
    • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
    • Be careful for the flex cable!
    • Disconnect the LCD display flex cable.
  10. Acer Iconia B1-711 LCD Display Replacement: stap 10, afbeelding 1 van 2 Acer Iconia B1-711 LCD Display Replacement: stap 10, afbeelding 2 van 2
    • This is the Logic board.
  11. Acer Iconia B1-711 LCD Display Replacement, LCD Display: stap 11, afbeelding 1 van 2 Acer Iconia B1-711 LCD Display Replacement, LCD Display: stap 11, afbeelding 2 van 2
    • Careful unstuck the metal folio from the screen shield.
    • Remove the 4x Phillips screws.
  12. Acer Iconia B1-711 LCD Display Replacement: stap 12, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 12, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 12, afbeelding 3 van 3
    • lift the screen shield from one side and open it like a door, then remove it.
  13. Acer Iconia B1-711 LCD Display Replacement: stap 13, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 13, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 13, afbeelding 3 van 3
    • The LCD display is held from the metal screen frame by several locking clips.
    • Very careful using a tool with sharp edge, release the screen from the one side.
  14. Acer Iconia B1-711 LCD Display Replacement: stap 14, afbeelding 1 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 14, afbeelding 2 van 3 Acer Iconia B1-711 LCD Display Replacement: stap 14, afbeelding 3 van 3
    • Lift the display up and remove it.
Conclusie
ZFix
191.278 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 2,338
