Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If you have a problem with the Audio Jack Connector, in this manual we will show you how to change it.
Wat je nodig hebt
Video overzicht
Switch-off the tablet.
Remove any SIM and/or Memory Card.
Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
Disconnect the Loudspeaker cable from the Logic board.
Disconnect and remove the Audio Jack Board flex cable.
Unscrew 2x Philips screws
Remove the board with the Audio Jack Connector.
Één opmerking
Can anyone suggest part number for whole jack board or just of jack?
