Ga door naar hoofdinhoud
Wat je nodig hebt
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: stap 1, afbeelding 3 van 3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: stap 2, afbeelding 1 van 3 Acer Iconia B1-710 Tablet Camera Replacement: stap 2, afbeelding 2 van 3 Acer Iconia B1-710 Tablet Camera Replacement: stap 2, afbeelding 3 van 3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: stap 4, afbeelding 1 van 2 Acer Iconia B1-710 Tablet Camera Replacement, Camera: stap 4, afbeelding 2 van 2
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: stap 5, afbeelding 1 van 2 Acer Iconia B1-710 Tablet Camera Replacement: stap 5, afbeelding 2 van 2
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: stap 6, afbeelding 1 van 2 Acer Iconia B1-710 Tablet Camera Replacement: stap 6, afbeelding 2 van 2
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: stap 7, afbeelding 1 van 3 Acer Iconia B1-710 Tablet Camera Replacement: stap 7, afbeelding 2 van 3 Acer Iconia B1-710 Tablet Camera Replacement: stap 7, afbeelding 3 van 3
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: stap 8, afbeelding 1 van 1
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: stap 9, afbeelding 1 van 3 Acer Iconia B1-710 Tablet Camera Replacement: stap 9, afbeelding 2 van 3 Acer Iconia B1-710 Tablet Camera Replacement: stap 9, afbeelding 3 van 3
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
Conclusie
To reassemble your device, follow the above instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Ryan Weber
358 Reputatie
3 handleidingen geschreven
IUPUI, Team S3-G5, Baechle Spring 2017 Lid van IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 303
