Inleiding
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Please SUBSCRIBE to my channel ツ
Video overzicht
  1. Switch-off the tablet. If you have a memory card inside, don't forget to remove it! Use a cutter and a plastic tool to remove the back cover.
    • Switch-off the tablet.
    • If you have a memory card inside, don't forget to remove it!
    • Use a cutter and a plastic tool to remove the back cover.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Disconnect the battery connector. The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it . The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
    • Disconnect the battery connector.
    • The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
  4. Li-on Batteri Pack, 3.8V, 2640mAh
Conclusie
ZFix
162.527 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
783 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 6
Afgelopen 7 Dagen: 28
Afgelopen 30 Dagen: 142
Altijd: 18,070
