Inleiding
This guide will lead you step by step on how to remove the speaker.
Wat je nodig hebt
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
Two 2.0 mm screws (with the bigger head)
Four 2.5 mm screws (with the smaller head)
Één andere persoon heeft deze handleiding voltooid.
