Ga door naar hoofdinhoud
Acer Iconia A110 Battery Replacement
Wat je nodig hebt
  1. Acer Iconia A110 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Iconia A110 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: stap 2, afbeelding 1 van 3 Acer Iconia A110 Battery Replacement: stap 2, afbeelding 2 van 3 Acer Iconia A110 Battery Replacement: stap 2, afbeelding 3 van 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: stap 3, afbeelding 1 van 3 Acer Iconia A110 Battery Replacement: stap 3, afbeelding 2 van 3 Acer Iconia A110 Battery Replacement: stap 3, afbeelding 3 van 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Andrea
757 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-42, Maness Spring 2014 Lid van Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Leden
Één opmerking
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 11,230
