Inleiding
Replacing the internal speakers in your tablet is fairly easy to do. Make sure you keep the screws you remove, you will need them to install the replacement speaker assembly.
Wat je nodig hebt
Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
Shut down your Acer Iconia A1-830.
Remove any cables or exterior covers from your tablet.
Place it on your work space, with the screen facing up.
Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
Remove the small clear plastic cover from the speaker connector with the metal tweezers.
Lift out the speaker connector using the metal tweezers.
Één andere persoon heeft deze handleiding voltooid.
