Ga door naar hoofdinhoud
Acer Iconia A1-830 Rear Facing Camera Replacement
Wat je nodig hebt
  1. Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: stap 1, afbeelding 1 van 2 Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: stap 1, afbeelding 2 van 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Rear Facing Camera Replacement: stap 2, afbeelding 1 van 2 Acer Iconia A1-830 Rear Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: stap 3, afbeelding 1 van 2 Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Rear Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Rear Facing Camera Replacement: stap 5, afbeelding 1 van 2 Acer Iconia A1-830 Rear Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Rear Facing Camera Replacement, Rear Facing Camera: stap 6, afbeelding 1 van 1
    • Remove the piece of black tape covering the rear facing camera ribbon cable connector.
  7. Acer Iconia A1-830 Rear Facing Camera Replacement: stap 7, afbeelding 1 van 2 Acer Iconia A1-830 Rear Facing Camera Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift up the small white lever on the the ribbon cable connector with the metal tweezers to remove the ribbon cable.
    • Lift out the rear facing camera from the plastic frame with the metal tweezers.
Conclusie
Brendan Coveney
593 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-6, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 428
