Inleiding
This guide will show you how to replace a camera in your tablet. This tiny digital camera is connected via a ribbon cable, which is hiding underneath some tape. You will need steady hands when you use the metal tweezers.
Wat je nodig hebt
Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
Shut down your Acer Iconia A1-830.
Remove any cables or exterior covers from your tablet.
Place it on your work space, with the screen facing up.
Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Peel off the piece of black tape covering the front facing camera ribbon cable.
Do this by holding down the ribbon cable and peeling off the tape with the metal tweezers.
