Ga door naar hoofdinhoud
Acer E5-571-54FL Cooling Fan Replacement
Wat je nodig hebt
  1. Acer E5-571-54FL Cooling Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Cooling Fan Replacement: stap 2, afbeelding 1 van 2 Acer E5-571-54FL Cooling Fan Replacement: stap 2, afbeelding 2 van 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Cooling Fan Replacement: stap 3, afbeelding 1 van 2 Acer E5-571-54FL Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Cooling Fan Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL Cooling Fan Replacement: stap 5, afbeelding 1 van 1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL Cooling Fan Replacement: stap 6, afbeelding 1 van 1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL Cooling Fan Replacement: stap 7, afbeelding 1 van 1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL Cooling Fan Replacement: stap 8, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 8, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 8, afbeelding 3 van 3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL Cooling Fan Replacement: stap 9, afbeelding 1 van 1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL Cooling Fan Replacement: stap 10, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 10, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 10, afbeelding 3 van 3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL Cooling Fan Replacement: stap 11, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 11, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 11, afbeelding 3 van 3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL Cooling Fan Replacement: stap 12, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 12, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 12, afbeelding 3 van 3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL Cooling Fan Replacement: stap 13, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 13, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 13, afbeelding 3 van 3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL Cooling Fan Replacement, Cooling Fan: stap 14, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement, Cooling Fan: stap 14, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement, Cooling Fan: stap 14, afbeelding 3 van 3
    • Locate the CPU cooling fan in the upper left corner of the laptop.
    • Using a #0 Phillips screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
  15. Acer E5-571-54FL Cooling Fan Replacement: stap 15, afbeelding 1 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 15, afbeelding 2 van 3 Acer E5-571-54FL Cooling Fan Replacement: stap 15, afbeelding 3 van 3
    • Place the tips of the ESD safe pointed tweezers between the plug and the socket of the fan connection.
    • Gently push the tweezers to the left to disconnect the fan plug.
    • Move the fan connector and its wires to free them from the motherboard and the WiFi card.
  16. Acer E5-571-54FL Cooling Fan Replacement: stap 16, afbeelding 1 van 2 Acer E5-571-54FL Cooling Fan Replacement: stap 16, afbeelding 2 van 2
    • Lift the curved end of the fan by about 30 degrees.
    • Use your hand to lift the fan up and to the right until it is clear of the case.
    • If you feel resistance, check if the fan connector and wires are stuck under the motherboard or under the WiFi card. If the connector or wires are stuck, gently free them.
Conclusie
Aaron Weissman
1.004 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G8, Bailey Fall 2017
UMASSD-BAILEY-F17S3G8
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 286
