Ga door naar hoofdinhoud
Acer Chromebook cb3-532-c47c LED Board Replacement
Wat je nodig hebt
  1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: stap 1, afbeelding 1 van 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c LED Board Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook cb3-532-c47c LED Board Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the battery cable: stap 3, afbeelding 1 van 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: stap 4, afbeelding 1 van 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: stap 4, afbeelding 2 van 2
    • Flip the retaining latch up with a spudger.
  5. Acer Chromebook cb3-532-c47c LED Board Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook cb3-532-c47c LED Board Replacement: stap 5, afbeelding 2 van 2
    • Pull the cable straight out away from the front of the computer.
  6. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: stap 6, afbeelding 1 van 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: stap 6, afbeelding 2 van 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: stap 6, afbeelding 3 van 3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jerry Wheeler
72.362 Reputatie
71 handleidingen geschreven
Oregonians Lid van Oregonians
Community
8 Leden
191 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 92
