Inleiding
This card connects the motherboard to the SD card and USB connectors.
Wat je nodig hebt
Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
Flip up the latch on the cable going from the I/O board to the LED board.
Flip up the latch on the cable from the I/O board to the motherboard.
Één andere persoon heeft deze handleiding voltooid.
