Inleiding
If several keys or the mouse/touch pad are unresponsive, or the entire keyboard on your Acer Chromebook (Spin 511 (C741L) N20Q8) stops registering your input, then a replacement is needed to be fully functional again.
Ensure that your laptop is powered down for this replacement, then follow this guide.
Wat je nodig hebt
Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
Gently remove the electrical tape from the battery.
Detach the colored wires from the wire connector on the motherboard.
Remove the battery from the laptop.
Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
