Ga door naar hoofdinhoud
Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement
Wat je nodig hebt
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 2, afbeelding 3 van 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: stap 3, afbeelding 1 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: stap 3, afbeelding 2 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: stap 3, afbeelding 3 van 3
    • Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the laptop by hand.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Touchpad: stap 5, afbeelding 1 van 1
    • Detach the ribbon cable from the touchpad.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 6, afbeelding 2 van 2
    • Remove the tan adhesive tape that is covering the touchpad to expose the screws holding it in.
    • Remove the three, 3mm long screws that are holding the touchpad in place.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: stap 7, afbeelding 2 van 2
    • Gently push the touchpad out with your hand.
Conclusie
Evan Costa
506 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Lid van UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 571
