Ga door naar hoofdinhoud
Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement
Wat je nodig hebt
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 2, afbeelding 3 van 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: stap 3, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: stap 3, afbeelding 2 van 2
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 4, afbeelding 3 van 3
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 5, afbeelding 1 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 5, afbeelding 2 van 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Microphone: stap 6, afbeelding 1 van 1
    • Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 7, afbeelding 2 van 2
    • Remove the microphone component from the rest of the computer by detaching the connected wire.
    • The camera component of the laptop is connected to the same wire, so remove this as well.
    • The camera is only held down with adhesives, so there is no need to use any tools.
  8. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 8, afbeelding 2 van 2
    • Remove the microphone and camera wire out from around the display screen.
    • Remove the ribbon cable at the bottom of the display screen to completely free the wire.
    • Carefully remove the adhesive tape and take out the ribbon cable.
  9. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 9, afbeelding 1 van 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: stap 9, afbeelding 2 van 2
    • Remove the microphone from the laptop.
Conclusie
Ian Sullivan
116 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Lid van UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 638
