Ga door naar hoofdinhoud
Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement
Wat je nodig hebt
  1. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: stap 1, afbeelding 1 van 2 Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: stap 1, afbeelding 2 van 2
    • Separate screen casing using a nylon spudger and a metal spudger.
  2. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: stap 2, afbeelding 1 van 1
    • Peel the tape back.
    • Lift the red bar laying across the connection with the spudger.
    • Pull the connection out.
  3. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the two cords shown by gently pulling them apart near their connection point.
  4. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: stap 4, afbeelding 1 van 1
    • Detach the connection by gently pulling on it.
  5. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: stap 5, afbeelding 1 van 1
    • Unravel the cord from around the screen and lift up on the screen to remove.
Conclusie
To reassemble your device, follow these instructions in reverse order with new LCD screen.
Bailey Johnson
691 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 433
