Ga door naar hoofdinhoud
Acer Chromebook R11 Speakers Replacement
Wat je nodig hebt
  1. Acer Chromebook R11 Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery by pulling upwards.
  5. Acer Chromebook R11 Speakers Replacement, Speakers: stap 5, afbeelding 1 van 2 Acer Chromebook R11 Speakers Replacement, Speakers: stap 5, afbeelding 2 van 2
    • Slide out black ribbons connecting speakers to motherboard
    • Connected on lower left-hand side of motherboard
    • When removing wires, remove gently with respect to metal clips along wires that are holding them in place.
    • Slide out white ribbon connecting keyboard to motherboard
  6. Acer Chromebook R11 Speakers Replacement: stap 6, afbeelding 1 van 1
    • Gently pull speakers upwards
    • Adhesive is below it
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Victoria May
119 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-2, Kass Spring 2017 Lid van USF Tampa, Team 1-2, Kass Spring 2017
USFT-KASS-S17S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 489
