Ga door naar hoofdinhoud
Acer Chromebook R11 C738T-C44Z Touchpad Replacement
Wat je nodig hebt
  1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: stap 2, afbeelding 1 van 2 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: stap 2, afbeelding 2 van 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: stap 5, afbeelding 1 van 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: stap 5, afbeelding 2 van 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: stap 5, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the touchpad.
    • Lift up the tab for the cable cord.
    • Pull out the touchpad connector.
  6. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: stap 6, afbeelding 1 van 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: stap 6, afbeelding 2 van 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: stap 6, afbeelding 3 van 3
    • Pull the left piece of tape up by prying it up with your fingers or with the screwdriver.
    • Be gentle to not rip the tape.
    • Next, pull up the other piece of tape.
    • Remove the touchpad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Connie Hernandez
517 Reputatie
4 handleidingen geschreven
Gateway, Team 1-4, Saknee Fall 2021 Lid van Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Leden
6 handleidingen geschreven
Één opmerking
Thank you, Connie Fernandez. ~Super
Super - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 395
